need to get support
Sue15
can't get full access due to confirmation number going to a number I don't have access to
how do you get help if you can't get into your account
Sue15
thank you for your help
hopefully customer support will be able to help to get into account
HI @Sue15
try again, try to just type out the message and not copy and paste
if you still get the same error when try to submit, then copy all the text you just type, delete them and the use "Paste as text" to paste the text again and should be ok
Sue15
thank you for this suggestion - it did get me to the page to do a private message but it is not letting me send it saying invalid HTML in the body and cannot send - says it has removed it but still wont' let me send
Sansan
@Sue15  you can send a direct message using below. Do you not have the option to get the code via email?
