need to create a ticket so signed up
jules007
Totally signed up and paid but get msg saying not registered on network
@jules007  - have you tried to restart your phone or perform a reset of the device's network settings?
Perform a Reset of your device's Network Settings.
This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
Also, try your SIM into another compatible phone to see if services work. If they work, then check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
@jules007 Phone showong SIM not registered or SIM not provisioned?  PM charged you already?
Just open ticket either PM support and they can quickly re-provision the sim to resolve the issue
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
DDM69
Assuming your SIM card is installed…try toggling airplane mode on and off or reset your device.
Welcome to Public Mobile! ☺️
