my service
murpharator
I have a voicemail notification on my phone, is there any ways to get rid of it?
@murpharator  - it will only go away once you listen to the voice message completely; OR, start to listen to the message then hit 7 to delete it while it is playing.
@murpharator
go to your device notification and turn off
but why you need it when you getting a voicemail
Help Articles (publicmobile.ca)
Check your voicemail messages (publicmobile.ca)
dabr
@murpharator    Usually that voicemail notification only disappears from your phone's home screen after you've retrieved the voicemail by holding down the #1 on your phone kepad.
Check your VM (from your phone or landline), delete the message if you don't need it
then go back to your phone and delete it from the notification.
