09-12-2022 01:29 PM
My phone number on my account is not mine, my actual phone number is showing as my alternate.
09-12-2022 08:34 PM
If you just activated very recently then you may have activated with a new number rather than a ported over one from another provider @kenmcl .
You can try to port the number now through your My Account. Make sure your previous account is still active for a successful port.
To change or transfer your number after activation, go to your Self Serve Account here and:
Your previous service provider may also send an SMS text to validate the transfer, so ensure your old SIM card is still in your device so you can receive and respond to this message. Please do not replace your old SIM card with your Public SIM until the number has been successfully transferred. "
https://www.publicmobile.ca/en/on/get-help/articles/port-fraud-protection
09-12-2022 04:34 PM
open ticket with PM support and ask them to check it.
At https://publicmobile.ca/chatbot.
have trouble with Chatbot: private message CS_Agent at:
Once ticket is submitted,(envelope icon on the top right) CS_Agent will reply you there.
09-12-2022 01:36 PM
Did you recently sign up? Did you attempt to transfer your number? Does your old sim still work?
09-12-2022 01:34 PM
Maybe page is just messed up.
Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh.
What number people see when you call them?
Alternate phone number is not important at all and you can remove it.
09-12-2022 01:31 PM
HI @kenmcl this is weird.
But for of all, can you receive inbound calls to your number you supposed to have?
The Alternative number field is not important, so, you can ignore that
