10-08-2024 11:05 AM
My phone suddenly was unable to connect to the internet with LTE and can only connect with the 4G band.
This issue occurred suddenly and has lasted all day. I installed a sim card from another network and everything is fine. the public mobile connection has no LTE data.
10-08-2024 11:18 AM
HI @Gar200
did you try put your PM sim card in another phone?
And on your usual phone, check if you have data limit set, maybe you reached the monthly limit and the device stopped the use of data
and try Reset All networks on your phone , too
