07-08-2021 04:49 PM - edited 01-06-2022 02:44 AM
When someone leaves me a phone voice message on my iphone 11, my phone does not say missed call so I do not know anyone has called me?
07-08-2021 08:53 PM
@portofino1170 wrote:When someone leaves me a phone voice message on my iphone 11, my phone does not say missed call so I do not know anyone has called me?
Hello @portofino1170 ,
Perform a Network reset, follow these steps.
07-08-2021 06:47 PM
Confirm if Allow Notifications is on
1) Open the Settings on your iPhone.
2) Select Notifications.
3) Scroll to and tap the Phone app.
4) Turn on the toggle for Allow Notifications.
Also, if you still find lots of missed calls, you might try to change your network setting to 3G Only
07-08-2021 06:43 PM - edited 07-08-2021 06:50 PM
Did you check to see the setting on the iPhone?
Disable the Do Not Disturb setting.
You may want to setup your voicemail box too.
07-08-2021 04:52 PM - edited 07-08-2021 04:53 PM
do you Set Up Voicemail
Voicemail requires you to have talk included in your plan, as accessing voicemail will use plan minutes. To access voicemail in the U.S., you will need to purchase the U.S. Roaming Add-On with Talk included. A maximum of 10 messages may be stored, with a maximum length of 5 minutes each. Voicemail messages will be automatically deleted after 10 days. You can recover them up to 48 hours after deletion by dialling in to your voicemail, then selecting ‘1’, followed by ‘9’. To protect your privacy, we recommend always requiring a password for voicemail access, even if you’re calling from your own phone.After you’ve activated, your voicemail is automatically ready to accept messages as soon as you add it to your account. It will play a default greeting until you set it up. Setting it up isn’t complicated:
do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
or can you try it selecting the network to "3G ONLY"
for iPhone visit HERE
or HERE
and do again Rebooting your phone means to turn off your phone and turn it back on again.
