02-27-2019 09:35 PM - edited 01-05-2022 03:31 AM
I cant get into my email and can't remember what my password or user name for my public mobile acct
02-27-2019 10:08 PM
@robinbanks44 wrote:I can use 611 but I am not in a big city so I cant put avocher on
Recharge.com
02-27-2019 10:04 PM
02-27-2019 10:02 PM
yes forgotvpasword and dont have the same phone or number so really stuck
02-27-2019 09:58 PM - edited 02-27-2019 10:07 PM
@robinbanks44 wrote:I cant get into my email and can't remember what my password or user name for my public mobile acct
But if you know your email address, you should be able to use the Forgot your password? link. Then it'll ask you a question you told it the answer to when you signed up. Then if it works it'll send you an email in a few minutes with a link to reset your password. But sometimes it doesn't work. Alas.
Edit: duh...Nevermind...you can't get in your email.
What is it that you need to do? The 611 service can use a pre-registered cc or entering vouchers to pay for service or add-ons.
02-27-2019 09:45 PM
thank
02-27-2019 09:44 PM
Ok good @robinbanks44 you will need to be patient now. They will help you. If you need to pay your plan you can buy voucher in store or at recharge.com...
02-27-2019 09:43 PM
yes thank you I have done all this and still nothing
02-27-2019 09:40 PM
Hello @robinbanks44
You can find it in the email from Public mobile for your activation. But if you don't remember your password too you will need to write a message to the moderator here...
and give them explanation of your problem. Waiting time is few hours to 2 days..be patient...
02-27-2019 09:39 PM
Private message the moderators...if you havent already ..
