11-05-2017 12:21 PM - edited 01-05-2022 03:31 AM
Current issue:
Phone can receive MMS but cannot send MMS.
Previous issue (now half fixed):
Phone could not send or receive MMS. I put some additions onto my APN which eventually fixed the receiving issue, but did not fix the sending issue.
Phone:
Samsung Galaxy S7 - Verizon Unlocked - Brand new and started using Oct 31 2017
Trouble Shooting:
Thank you for your time and I hope someone can help me figure out why my phone cannot send MMS
09-06-2019 04:56 AM - edited 09-06-2019 04:57 AM
09-06-2019 04:54 AM
A similar thing happened to me where I had my mms messaging working but then inputed different apn settings to test something. After I switched back to my original apn settings, my phone could no longer send or recieve mms messages. Were you able to fix the issue when it happened to you? Thanks!
11-06-2017 08:43 AM
Awesome! Looks like you had a typo in the original screenshot (hhtp instead of http).
11-06-2017 08:21 AM
Glad you got it working.
11-06-2017 02:44 AM - edited 11-06-2017 02:47 AM
11-05-2017 06:02 PM
Have you tried changing the CSC to TLS (Telus)? It would remove Verizon restrictions from your phone's software.
11-05-2017 05:57 PM
Hello SMBrossard,
Thank you for reaching out to us.
In order to better assist you, please send us a Private Message.
Cheers
Abdoulaye
11-05-2017 04:12 PM
Odd, well then this is likely a back-end issue that the mods need to take a look at. I've just testing mine and I've sent and received and MMS with those APN settings.
I'm sure you know, but use this link to send the mods a private message: @CS_Agent
11-05-2017 04:09 PM - edited 11-05-2017 04:10 PM
I tried your APN and it did not work, the MMS would not receive and it would not send as well.
A bigger issue now is that when I put my old APN in, my phone no longer receives MMS, when before it was only an issue with sending.
I have now gone back a step in my progress ![]()
When you say you "reset" your phone, is this a factory reset? or simply restarting the phone?
11-05-2017 01:13 PM
I'm also using an s7 on PM, using the Canadian version of the phone (SM-G930W8) but our APN settings should be the same. I was having this issue for a day or two but re-entering the APN and a reset appears to have done the trick for me.
See below for my screenshots:
