10-22-2021 10:05 AM - edited 01-06-2022 03:34 AM
Hello,
My son continually loses phone service in an area where coverage is provided. His friends always have service but not sure who they have for providers but why can't he? We tried to turn the phone off and on for a refresh but no luck. He does have wifi but no SIM card service for texting or making calls.
Thank you in advance. 🙂
10-22-2021 04:44 PM
Has this always been an issue with the iPhone or more recent? Is the mobile data unaffected? You mention that both calls and texts are affected so this is not related to 3G only service as texts work both on 4G LTE and 3G networks. Where did you acquire the iPhone? Have you tested the sim card in another phone? This helps determine if it's a device or pm/sim card issue.
10-22-2021 04:25 PM - edited 10-22-2021 05:11 PM
@Momma22 wrote:My son continually loses phone service in an area where coverage is provided. His friends always have service but not sure who they have for providers but why can't he? We tried to turn the phone off and on for a refresh but no luck. He does have wifi but no SIM card service for texting or making calls.
If the suggestion of trying your SIM card in another phone doesn't help, you may wish to consider another carrier (usually Rogers because going to Bell, Virgin, Lucky, Telus, Koodo, etc. won't improve things). Some phones do have a slighty better antenna than others, but that doesn't necessarily mean that there is anything wrong with the current device.
10-22-2021 12:46 PM
10-22-2021 12:29 PM
Thank you! I will try those steps and see how it goes. As for the other one, that is what i tried earlier and there isn't an option to change between those options. 😞 It is an iPhone 6
10-22-2021 12:27 PM - edited 10-22-2021 12:27 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and try manually selecting network "3G ONLY"
for iPhone visit Here link
or Here link
and do Rebooting your phone
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
Ensure you have the correct APN settings by visit Here link,
and if still not fix it please you Have To Submit a Ticket To Contact Customer Support Agent by CS_Agent ,and Explain your issue to they can solve your issue, they are nice service Team the will help you 100%.
Here’s how to contact Customer Support Agent by CS_Agent,
Good Luck..
10-22-2021 12:23 PM
Hello again. I looked at his phone a little bit ago and the only option is to turn auto off and then there is the option to change to another network but of course, it wouldn't work on another network.
10-22-2021 12:22 PM
Well, I looked at his phone and there isn't any other option on that but to leave it on auto. When I turn it off it gives the option to choose another network but of course, there is no service when one of them are selected.
10-22-2021 11:30 AM
@Momma22 wrote:Hello,
You can also try these tips:
1) Put the SIM card in another phone (an android is fine too) to see if all features work.
2) Check and install all system/software updates available for the phone.
3) Do a Reset network settings.
Keep us posted and we'll see if we can suggest something else.
10-22-2021 10:20 AM
We are in Nova Scotia. He has an iPhone which I am not a fan of but that's what he wanted. I will take a look later today and see if it works. Thank you!
10-22-2021 10:18 AM
Hello, We are in Nova Scotia. He has an iPhone...not a fan of them but that's what he wanted. I will see what I can do. 🙂
10-22-2021 10:16 AM
Thank you!! I will see if I can get that to work. It would be nice to be able to have that fixed.
10-22-2021 10:16 AM
@Momma22 : Whereabouts are you? What phone? Can you try switching network type to any of 3G/UMTS/WCDMA/HSPA.
10-22-2021 10:14 AM
Public mobile uses with Telus or Bell cell towers so in general reception is good. However, in certain areas, other mobile company reception may be better.
Try to manually select your son's phone to the 3G network (instead of LTE or auto). In some areas, the 3G network with Public mobile offers better reception and even faster data speeds.
