08-27-2022 03:35 AM
My account worked with selfserve.publicmobile.ca in the past, but not any more with the long address starting with telusidentity.telus.com.
I have saved logins in my computer, so the username & password are 100% correct. I tried suggestions in the forum, e.g., private mode or different browsers. Unfortunately, none of them worked. I tried reset my password, but no validate code came to my email. Please confirm whether it is caused by changes in the account system (website domain/database), and when it will come back to normal. Thanks.
08-27-2022 09:03 PM
Thanks again. I tried your suggestions.
I was using exact the same device & network when it works last time (with selfserve.publicmobile.ca).
So I can't find any clue from my side.
08-27-2022 11:38 AM
Did you click on the Sign In link top right and select My Account in the drop down? Did you try all this on an unaltered open browser (not all locked down with add-ons and filters and whatnot). Are you out of country? Are you using a VPN? Can you?
The site should work. Just that it's very intolerant of anything out of the norm.
08-27-2022 11:31 AM
In such case, ticket to PM support is the only way to try to get it resolved. It is true that some user had the same issue for whatever reason
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
08-27-2022 11:27 AM
I tried but didn't work. Thanks anyway.
08-27-2022 11:26 AM
Thanks.
Asking the code through my phone number is not really feasible for me because I am outside PM network right now.
Tried typing the website address directly, no luck unfortunately.
08-27-2022 11:23 AM
This has been grade school level IT system roll out. Terrible.
Have you also tried a different device?
08-27-2022 11:19 AM
Thanks. I tried your suggestion, but it didn't work for me.
Even the username and password are correct, the system just does not let me in. That's why I am asking whether the system has some issue. It is very common when a system is updating.
08-27-2022 09:21 AM
@ABNS wrote:My account worked with selfserve.publicmobile.ca in the past, but not any more with the long address starting with telusidentity.telus.com.
@ABNS did you try to reset password by asking the code to send the phone number? This option will work as long as your phone is not currently suspended
https://myaccount.publicmobile.ca/en/forgot-password
And, if you are accessing the site via any bookmark, do not use that, try to just use https://selfserve.publicmobile.ca/ (yes, the system will redirect you to Telus server after)
If you have any browser extension for dark theme, like Dark Reader, please also disable it.
08-27-2022 04:10 AM - edited 08-27-2022 04:13 AM
if you have username & password are 100% correct. why you do reset password.
tried use browser from computer,and clear cache and cookies and use one page inPrivate mode,or safari on private mode, or use other device machine to open browser,
To Login Page
you will get verification code by email or SMS
and inserting the 6 digit number and not press anything
just wait a 5 second automatically be login,,
if want to Reset Password
after successful reset passowrd the close all browser, and one page inPrivate mode.
08-27-2022 03:51 AM
Try logging in using secret/incognito mode on your phone instead of your computer and manually input the login and passwords and see if that works for you?
