login Error
Xz_yan
the error code is ("massage": "unauthorized")
9 REPLIES 9
@Xz_yan i've gotten that recently, but it past after I tried again later. I didn't even have to clear cache or go incognito. But if your service is not working now, that is different.
Have you restarted your phone or removed and reinserted your SIM card, or tried your SIM card into another phone to see if services work?
What happens when you dial # 1-855-478-2542 or # 1-855-4PUBLIC to check the status of your account?
Did you have any suspicious transactions your reported on your credit card statement lately? If it something like that was reported from a public transaction, this could mess your account up. If this is the case, submit a ticket with CSA by methods provided to get this sorted out.
@Xz_yan   I think I saw this as an account issue and need PM support to look into it
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
@Xz_yan @You can get a voucher and do 611 no pin needed
you May need support if your reset  password and still can’t get in
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here
  • you can send a private message to our  CS_Agents by clicking here.
@HALIMACS
I've read about unauthorized messages.  🤗
Xz_yan
It has been three days. I tried to login in through different devices. Iphone, Macbook and Sumsung phone. I did turned off and restart the phones. I got all same error message. And not able to reset password too. Now the my service off on the line, even*611, couldn't help.
pmbc
What browser are you using?  I've found that Edge dev doesn't work and I have to use a different browser.
HALIMACS
That sounds like an interesting "massage", @Xz_yan    😉
@Xz_yan   Try logging in with Incognito mode or another browser and it should work
@Xz_yan @Try again incognito mode private mode or even try another device or laptop
