01-14-2018 08:51 PM - edited 01-04-2022 03:19 PM
im wondering if 2600 & 700mhz is availible to public mobile customers or just bell and telus
because my phone will not connect to that band (7), (12) (13) (17) or it doesnt support it
model is a lg k4 2016 unlocked and bought from chatr wireless
i also looked at other discussions on here and doesnt really make sense to me
Phones
01-15-2018 03:54 PM
k i thank everyone for the proper info all tho im a comuter tech my self
01-15-2018 03:44 PM - edited 01-15-2018 03:44 PM
@georgepacan wrote:Ohh! I thought it uses aws for both 3g and lte
@georgepacan no. Only Freedom Mobile uses AWS for 3G in Canada, while Rogers, Bell, and Telus all use band 2 and 5 for UMTS/HSPA 3G network. Except in a few areas (parts of Ontario for example), Freedom does not use AWS (called Band 4 for 4G LTE purposes) at all, and instead delivers LTE via band 66, with the exception of some areas as I noted. Bell, Rogers, and Telus all use Band 4 (AWS) as their primary LTE band, but also use, in some areas, some combinations of bands 2, 5, 7, 12, 13, 17, and a few others for LTE delivery to augment band 4 AWS LTE.
01-15-2018 02:21 PM
01-15-2018 02:16 PM - edited 01-15-2018 02:17 PM
@georgepacan sure, though in fairness it is names *LTE* Discovery! Sorry, is your question asking about 3G? If so, PM uses bands 2 and 5, 850 and 1900 MHz. Edit: Telus does not use AWS for 3G, only Freedom does so in Canada. The rest (including Chatr) use 3G bands 2 and 5.
01-15-2018 02:10 PM
I had that app b4 but it doesn't show hspa bands
01-15-2018 02:07 PM
@NDesai wrote:
@georgepacanwrote:I type 277634#*#* and then i select some options
This might be a phone brand specific.
@R47 See here: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Fun-with-LTE-Discovery-widget-LTE-ban...
Thanks @NDesai, I was going to metion that LTE Discovery can show you your current band, but you beat my to it by a day :). @R47 please see that link above. I think the widget may only be available if you buy the premium version of the app (I don't recall it being expensive), but the app itself can show it even in the free version IIRC.
01-15-2018 01:57 PM - edited 01-15-2018 01:58 PM
Well i can only connect to telus in search networks and its all ok now i had to reset my apn, etc
I live in a fringe area so my bars fluctuate a lot
01-15-2018 10:02 AM
this is my go to site:
@georgepacan wrote:im wondering if 2600 & 700mhz is availible to public mobile customers or just bell and telus
According to the site provided it should be supported... if it isn't, maybe the site should not be my go to!
01-15-2018 06:29 AM - edited 01-15-2018 06:32 AM
As already mentioned by others, B7, B12, B13, B17 are certainly available from the network. Whether all bands are available in your specific area, or whether your phone supports them is another question.
See cell site locations here:
https://www.ertyu.org/steven_nikkel/cancellsites.html
You can connect to any Bell, Telus, or Sasktel 3G or LTE site.
If you have more questions, just ask.
01-15-2018 03:48 AM
The information provided in that screenshot is just plain wrong for GSM. There is no 2g GSM network for Public Mobile. In addition, the LTE compatibility list is incomplete.
And yes, there is 2600MHz available on LTE for Public Mobile customers in certain areas.
01-15-2018 12:10 AM
01-14-2018 11:09 PM
01-14-2018 11:05 PM
Just wondering, how can you check what band you're connected to with Android?
01-14-2018 10:54 PM
My k4 uses aws 1700/2100 for lte and i think the same for hspa or 1900 for hspa
01-14-2018 10:53 PM - edited 01-14-2018 10:57 PM
Thanks, I stand corrected.
I got that info from here:https://apn-canada.gishan.net/net_15_public_mobile_internet_and_mms_settings.php
Looks like that site needs some correction
01-14-2018 10:51 PM - edited 01-14-2018 10:52 PM
PM uses the Telus network so this is the current summary:
As you can see, 2600 (band 7) is available only in certain areas and 700 (12/13/17/29) is listed as being used for rural areas so if your phone isn't connecting to these then either your phone doesn't support them or the towers you are connecting to aren't providing them.
I don't know if your LG K4 has different variants but a quick look seems to say it supports bands 2, 4, 5 and 13 - this should be enough to get LTE in most places.
A really good post is @sheytoon's: What frequencies does my phone need to work on Public Mobile?
@Lg85- your screenshot seems to be outdated, PM uses the Telus network and has access to all the Telus frequencies/bands.
EDIT: @wetcoaster beat me to it! 🙂
01-14-2018 10:49 PM
Its ok imma switch back to chatr
01-14-2018 10:45 PM - edited 01-14-2018 10:46 PM
@Lg85 wrote:
Below are the network frequencies for Public Mobile for its 2G, 3G, and 4G networks.
Looks like it will not connect to 2600 and 700MHz.
There is something wrong with the information you've posted... Public Mobile uses the Telus network and Telus has never supported 2G GSM (their orignal cell network was on CDMA, different technology). So a 2G GSM only phone that works on the Rogers network doesn't work on the Bell / Telus network.
Please refer to @sheytoon's post here for required bands:
@sheytoon wrote:Minimum recommended phone specs:
- 3G UMTS/W-CDMA/HSPA: B2 (1900) and B5 (850)
- 4G FDD-LTE: B4, B5, B12/B17
Currently VoLTE is not available and voice calls are only on 3G. SMS and data can work on 3G or LTE. Fastest data speeds are on LTE.
For LTE, these are all of the available bands on the network: 2, 4, 5, 7, 12, 13, 17, 29, 30. Some bands are available in some locations, others available elsewhere. B66 will be coming next.
Any phone you are considering should have B4, B5, B12 (or B17 instead of B12) for minimum coverage.
B2, B7 (and B66 shortly) will give you faster speeds. The rest are not really necessary.
Full thread: https://productioncommunity.publicmobile.ca/t5/forums/replypage/board-id/Discussions/message-id/5822...
01-14-2018 10:41 PM
Yes, you are right. It looks like both Telus and Bell has the LTE Band 7 2600 MHz frequency, not Public Mobile.
01-14-2018 10:30 PM
@Lg85 i noticed when i put back in my chatr sim the signal is very strong indoors and stable, telus towers sucks weak coverage indoors especially basements
01-14-2018 10:27 PM
@Lg85 ya i know but when i select band 2 it connects to that band of LTE
01-14-2018 10:20 PM - edited 01-14-2018 10:26 PM
