Cannot Receive Phone Calls
01-14-2018 06:02 PM - edited 01-04-2022 03:19 PM
Hello,
Just changed over to public mobile. I can Send & Receive text messages from phones outside public mobile and make calls, but when I call my phone number (or have a friend try) it goes straight to voicemail.
Any suggestions? Have tried turning phone on and off. Switched at 18:23, January 14
Joining Public
01-15-2018 06:49 AM - edited 01-15-2018 06:51 AM
Old SIM does not work.
I can make calls (my old number shows up), send text to some phone numbers, receive texts, go online, but cannot receive phone calls. I have messaged the moderators.
7:48, January 15, Atlantic Standard time.
01-15-2018 06:02 AM
@stumac94 Try your old SIM. If it works just keep using it until the PM SIM is functional. Do not close your old account; that will happen automatically. Or if you have another phone, use your old SIM in it and carry on with two phones
If your port-in of a cell number has stalled more than 3 hours you will need moderator assistance. If so, send a private message to the moderator team with your phone number, SIM #, and an explanation.
01-14-2018 08:40 PM - edited 01-14-2018 08:41 PM
please let us know if anything else goes wrong or have any questions, have a great day!
01-14-2018 07:49 PM
All of that is done.
Will update tomorrow.
01-14-2018 06:49 PM
@Mana i just said that lol
01-14-2018 06:34 PM
@stumac94 if you have just ported your number from your previous service provider, it may take some time to complete the port.
01-14-2018 06:21 PM
@stumac94 also if you have province wide talk plan and ur in another province you will not receive or make calls text etc
01-14-2018 06:19 PM
@stumac94 the number can take a few minutes to hrs to port and make sure you select auto search for network and gsm/wcdma/ lte auto and youll be good to go
01-14-2018 06:12 PM - edited 01-14-2018 06:14 PM
Delorean travelling at 88mph... There are no lottery ticket numbers near me so dont bother asking.
Should have specified 18:23 atlantic standard time. (roughly 50 minutes ago)
switched over from Bell, kept my original number.
01-14-2018 06:08 PM
Actually, where are you located. A bit short sighted of me to assume we are in the same time zone...
01-14-2018 06:05 PM - edited 01-14-2018 06:06 PM
@stumac94, What's the secret to going to the future?
Kidding asside, how long has it been? Did you port over a number, or did you have a new number assigned?
