03-17-2025 04:36 PM
Hi there. I'm in Mexico and confused as to whether incoming AND outgoing texts are free. My plan says Canada wide calling etc and International texts/images
Does that include incoming and outgoing texts from Mexico to Canada?
03-17-2025 08:16 PM
When you are connected to wifi. You are sending and receiving text on WhatsApp, iMessage or RCS and there are no charge on PM prepaid plans.
03-17-2025 04:49 PM
@sralphy wrote:I am currently sending and receiving messages but don't know if I am being charged or if it's included. My usage history shows them as incoming and outgoing but not sure about $.
Public Mobile doesn't have pay per-use-charges, so there's no need to be concerned about possible charges.
03-17-2025 04:49 PM
@sralphy the nice thing about Public Mobile is that there are no surprise charges so you won't get billed for going over data (it will just stop when the amount has been used up) and roaming is not supposed to work if you do not have a roaming plan or add-ons. Have you gone into your Public Mobile app to confirm which plan your are currently on? If you go to the main tab, then go to Manage Subscription, it will show the details of your plan
03-17-2025 04:46 PM
03-17-2025 04:41 PM
@sralphy international texts will only work while you are in Canada, nowhere else. You would need a Canada-US-Mexico plan for you to be able to send texts back to Canada or to the US and even within Mexico (while there)
03-17-2025 04:40 PM
@sralphy wrote:Hi there. I'm in Mexico and confused as to whether incoming AND outgoing texts are free. My plan says Canada wide calling etc and International texts/images
Service is only included in Mexico if your Public Mobile plan was advertised as a Canada-US-Mexico plan. Otherwise, your service won't work there.
