invalid sim
11-04-2018 09:41 AM - edited 01-05-2022 02:24 AM
I have a blackberry bold and I get a prompt that the sim is invalid emergency calls only but the sim works in another phone like a samsung ? does anyone know what the problem might be ?Thank you
Phones
11-04-2018 10:22 AM - edited 11-04-2018 10:26 AM
The fine print around these parts says that for data BB OS10 is needed. I have the Z30 and
everything works as it should. Your Bold is older.
There are several models of the Bold so we can't tell from our vantage point.
You might get talk and/or text but no data. You might need to fiddle with which frequencies to pick up.
11-04-2018 10:18 AM
looks like your bold isnt compatible.
try to do a network search and see if it can find PM network.
11-04-2018 09:50 AM
Check the website to check if your model of Blackberry Bold is compatable with Public Mobile:
http://www.willmyphonework.net/
I have a feeling that it is NOT compatible....
11-04-2018 09:44 AM
If this is for a new acct on a used phone...make sure the phone is unlocked. If not, you can call the previous cell provider and request a free unlock code. Alternatively, you can buy one on eBay. Good luck.
11-04-2018 09:44 AM
I think the blackberry needs to be a blackberry 10 device..dont think a bold is..
