internet connection problem
Carolqu
Hi all, I have been with PM for 6 months without issues. This morning my ios10 phone lost connection. I see LTE but there is no internet connection. I checked APN settings and they look good. I checked the self portal and account is active. I've rebooted it 3 times and tried removing the sim. Any thoughts?
useful links for leisure time:
https://culonasxxx.cc
https://pornoculonas.cc
https://culonas.tv
@Carolqu  which city and province you are at?
and you can check if your phone is blacklisted here as well
https://www.devicecheck.ca/check-status-device-canada/
hycm53
@Carolqu  If you bought the second one then make sure is not in blacklist:
https://www.imeipro.info/
@Carolqu
What iPhone do you have because the latest update is iOS 16.0.3?
Also what plan are you on?
Try login out then back on and see how much data you have left.
dust2dust
When you were checking the self-portal, did you notice if you had used all your data? Click on the little spinner refresh icons lower down or use private mode to make sure the information is current.
I'm sure you've turned on cellular data and that your browser has permission to use cellular data?
