01-17-2021 09:33 PM - edited 01-06-2022 01:52 AM
Hi! I have issue with incoming calls going to voice mail. Outgoing calls and in/out sms without problems. Help please.
01-22-2021 02:44 PM
@starikovvv wrote:Hi! I have issue with incoming calls going to voice mail. Outgoing calls and in/out sms without problems. Help please.
@starikovvvThere is a known issue in the Kitchener-Waterloo area where incoming calls fail in this way if your phone has LTE enabled. Make the change to 3G/WCDMA/HSPA mode only with LTE disabled as @hoagie_waterloo previously suggested as a workaround until the issue is resolved.
01-22-2021 12:04 PM
I was having the same issue. I went to settings/mobile networks/network mode. I changed my network mode to WCDMA only and everything works fine now.
01-17-2021 10:35 PM
You can also try the SIM card in another working phone. That would help determine whether it is a hardware issue versus Public public service problem.
Another thing to try is to manually select 3G (instead of LTE).
01-17-2021 10:01 PM
Is call-forwarding set to 'always forward'?
Is Bluetooth turned on - try switching off.
If any troubleshooting fails, and it's been several hours after activating, I would contact Public Mobile moderators.
To contact a moderator, there are 2 methods:
01-17-2021 09:53 PM
Done, but didn't help....
01-17-2021 09:48 PM - edited 01-17-2021 09:51 PM
Try powering off device, remove SIM, power on device, then reinsert SIM.
01-17-2021 09:46 PM
new sim card (without transfer)
SMS incomes from the same number, but the call does not come and goes to voice mail
01-17-2021 09:41 PM
Not Disturb turned off: in/out sms working
01-17-2021 09:36 PM
Did you request a phone number to be ported in? If yes, are you receiving text messages from everyone or just text messages from other Telus, Kooodo, and Public customers? If you ask for a number to be ported to Public Mobile, no incoming calls could be an indication that porting isn't complete. That voicemail that callers are hearing could also be from the recorded greeting at your old carrier.
01-17-2021 09:36 PM
Could Do Not Disturb be turned on, @starikovvv ?
