04-08-2024 10:00 PM - last edited on 04-09-2024 12:07 AM by computergeek541
Something happened recently. I switched 3 weeks ago, everything was fine all ported over. Now I can't get incoming calls. When people try to call me it goes to Rogers voicemail! Which I do not have anymore. My phone does not ring. I can make outgoing calls and it comes up as my number.
I also tried to open a ticket here but it was quite a pain and I can't find any record of it.
Third, when I signed up it said free sim card. But it wouldn't let me get one. So I went to the Telus store and had to buy one. How do I get a refund for that?
04-08-2024 10:11 PM
@Mmzah do you still have the old provider sim card?? test it. If it works, the port was never completed
either way, there is a number to call to talk to live support, they can check the porting status for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
