Friday
Afternoon, looking for help on redownloading the esim. Looks like i paid 2x for it and i have waited past 5 hours and no data or voice. (supposed to be free) no idea why i got another esim 🙂
I do not have a qr code to redownload the the esim, please help or i need to go back to my provider. 😞
Friday
Esim paid 2x
Friday
DO NOT remove (delete) PM esim if it is there.
even for other carrier's esims, better to disable and not delete
and if same, please submit ticket with PM agent as said in my earlier post
Friday
Thank you, i removed my Sim and still nothing. I think i will remove all esims and hope to scan a QR code some where again.
Friday - last edited Sunday
the esim probably is installed and just not configured properly
you might first make sure the old carrier sim is removed or disabled if it is an esim
And Go to Settings-> Cellular or sim manager and make sure the Public Mobile esim is there and enabled (or Turn on this line option is enabled) and set as Primary. Then Reset Network Settings.
In case you don't see a Publc Mobile esim there, check the Welcome email from PM and there is a QR code to scan and install the esim
If you still need further help, ask support agent . You can submit ticket by direct message:
Friday
Sorry i read to download esim again and clicked on getting another. I don't have a QR code to redownload.
Friday
did you pay 2x for the plan or for esim? did you try reset network settings?
if you need PM to help, open a ticket. You won't be able to open proper Chatbot ticket, so just message them
