12-07-2022
03:28 PM
12-18-2022
11:15 AM
Dunkman
12-07-2022 03:37 PM - edited 12-07-2022 03:38 PM
Another option is to try force restart your phone. The ugly red dot showed up on my phone after the update - tried many options, force-restart solved the problem. It may work for you.
https://support.apple.com/en-ca/guide/iphone/iph8903c3ee6/ios
12-07-2022 03:34 PM
iOS 16.1.2 is the latest update. You are on the old update.
Try updating it to iOS 16.1.2 and see if that helps. Also check to see if Cellular data is enabled.
12-07-2022 03:29 PM
HI @Mgreene
Mobile data works?
Make sure you update your Carrier profile
If that does not work, try to Reset All network
