05-20-2015 03:42 PM - edited 01-04-2022 12:38 PM
I recently activated my SIM card and works in my iPhone 4 I can receive texts and calls and also the wifi works but when I am out of range of wifi I have no data available I have the 2 g plan . I saw the post regarding apn settings but do not have more than one field to change I do not see the more than apn and hotspot please help I am so frustrated
05-20-2015 06:38 PM
Android is better.
Apple have too much restrictions. They control what they want on your phone.
Can you try from your iPhone browser the iPhone APN changer.
Click on http://www.unlockit.co.nz/unlockit/ and follow instructions.
05-20-2015 05:15 PM
05-20-2015 05:13 PM
05-20-2015 04:05 PM
iPhone 4 cannot update to iOS 8.3. Only iPhone 4s and newer can update to iOS 8.3
Apple products are so bad...
05-20-2015 04:01 PM
05-20-2015 03:44 PM
In order to have functionnal MMS and DATA (internet), you need to configure your APN. However, some iPhone 4 and older have not access to that options.
If it's not possible to edit your APN, then you need to update your iOS version to 8.3 (current version from Apple).
Step-by-step APN configuration :
English version
1. Insert your Public Mobile SIM card into your unlocked iPhone.
2. Tap “Settings”
3. Tap “Cellular”
4. Tap “Cellular Data Network”
5. Change your APN values to match the table below:
*Only update the fields that are circled. Leave every other field empty
Internet tethering could be also shown as Personal Hotspot
If I answered your question, please accept my post, as the solution.
