05-20-2015 07:00 PM - edited 01-04-2022 12:38 PM
I have not received my text message to verify the code.
Please email me at r****************m
Joining Public
08-31-2018 03:29 PM
Hi Ted, welcome to Public Mobile!
Looks like you're trying to activate a new account, am I right? You've probably just activated your SIM card?
What's the step you've just completed, I think you now need to go to http://selfserve.publicmobile.ca and create your account. If this is correct, there will be a Create Account button on that webpage.
08-31-2018 03:05 PM
Thank you, but now that my email has been verified following the email that you sent, what do I do next? Thx in advance.
Ted Sheldon
01-25-2018 12:45 PM
This thread is from May 2015 and marked as solved...
01-25-2018 12:37 PM
Can you try doing it again, and Attaching a screen shot?
(Crop / Blur out any personal information) It would just help to see the message you are
05-20-2015 07:56 PM
Please enter the 6-digit code exactly as you see in the text message.
05-20-2015 07:53 PM
I have tried as you suggested but it says invalid sim. What now?
05-20-2015 07:43 PM
To create and activate a new SIM card, you simply have to go on : https://activate.publicmobile.ca
I opened 3 accounts with Public Mobile and I was never prompted about a "code" send by SMS.
05-20-2015 07:36 PM - edited 05-20-2015 07:42 PM
After I set up my sim and changed my phone number...I was told that I would receive a text message and to follow the instructions on how to start an account on line. But I have not received anthing and this has been 4 hours ago. I am referring to the 6 digit code used to verify your registry for an account.
05-20-2015 07:25 PM
