04-19-2024 10:34 PM
Hi got a plan 2 days ago on eSIM.
Everything works well. Data, phone but sms are not sending / receiving.
APN : isp.mb.com
I tried changing it to SP.MB.COM but same result.
Powered off and on .
only thing I didn’t do it reset network setting as I don’t want to loose my wifi password. Would do it if I was sure it would solve my issue but I have doubts …
04-20-2024 08:02 AM
self solution removed
04-20-2024 07:40 AM
Problem is solved. Got this from support this morning :
Hello there!
My name is XXXXX and I will be happy to help you today.
Please restart your phone, I reset the SMS Center number.
If necessary, visit Settings, Reset, Reset Network, nothing else.
Kind Regards
XXXXX
CS_Agent PM
04-19-2024 10:41 PM
Thanks @hTideGnow
I just used your link to submit a ticket. 🙏
04-19-2024 10:36 PM
HI @PierreDan
Yes, if only SMS an issue, it is a PM system problem with new activation. Voice, data both work but just SMS is the problem. And with the SMS problem, it will affect account verification. PM is aware of the problem and can only fix the issue one account at a time.
Please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
