iNTERNATIONAL CALLING
vencott
How can i make an international call using my current plan ($30 for 30 days) i've pluchased 300 intl mins for $15 but still getting a recording that voice in not included in my plan
18 REPLIES 18
vencott
i ended up using Rebtel, worked fine. Thanks again.
Checked Rebtel - about 25c/min
Shaw Prepaid / Goldline is 33c/min
But TextNow app is the winner at 9c/min !
@vencott wrote:
really ?, so there is now way to call Jamaica ?
Have a look at CiCi mobile: https://www.ciciphonecard.com/rates. Expensive place to call. 😢
Depending on the actual number Fongo might be cheaper: https://account.fongo.com/calling/long-distance/#J
vencott
yea, i will, i didnt even realize that the countries were listed, i just assumed i was able to call
@vencott wrote:
that would be just as good thanks, i'll ask.
Good luck...maybe rather than asking for a refund; you could ask for a $15 credit applied to your Available Funds. Be nice about it...after all, you made the error.
vencott
 @vencott : Yes, generally there aren't refunds here. A list of countries is shown in two places on the purchasing screen.
Maybe the moderators would do a nice goodwill for you and credit your account. But not a full refund.
@vencott wrote:
how can i cancel my add-on for 300 mins
You forgot to do some research before you bought the add-on...that's on you. No refunds ....usually. You can check with a moderator to see if a refund is possible but don't be surprised if the request is rejected.
Happy Holidays.
If you get a Text Now number you can call for free using Wifi
vencott
Or use a voip app like TextNow.
Get a Jam calling card at you local 7-11 type of retail outlet.
vencott
@vencott wrote:
trying to call Jamaica
You won't be able to call Jam on the PM network as that country isn't available...yet.
That's not on the list. Nor is it available.
vencott
Is the country you're trying to call on the list of countries of that add-on?
Is your account active?
Are you dialing 011 and then country code and then area code and then the number? Perhaps drop leading zero's in the country code or area code.
hairbag1
@vencott...
let us know which country you're wanting to call.
