04-09-2024
12:30 PM
04-09-2024
05:49 PM
computergeek541
01-07-2025 12:06 PM
Just ported over 2 different phones and had the same problem. Check in Settings > Apps > Messages > Send & Receive, make sure that your phone number is selected/enabled for Messages. Optionally check your "start new conversations from" is what you want.
If it just spins while trying to activate your phone number, power cycle your phone. Mine activated right away after rebooting.
04-09-2024 02:54 PM
@Matt2002 we have received a number of posts confirming this issue, and our teams are currently working towards a resolution asap. Apologies for the inconvenience.
04-09-2024 02:18 PM
@Matt2002 I can't say for certain this is your problem, but this happens to me every time I port - I need to manually reactivate my phone number within iMessage. It seems that when iMessage sees a change in SIMs, that it assumes you have a new number and so you have to manually agree to use the number.
To check this, go to Settings/Messages/Send & Receive and confirm that there is a checkmark next to your phone number. If there isn't, tap it and you should be good.
04-09-2024 01:59 PM
Like Handy1 said earlier tons of issues with SMS on new activations, I am in the same situation have been waiting since Sunday morning and have not got a reply yet.
04-09-2024 01:17 PM
I contacted Apple first and they said after troubleshooting to contact my provider
04-09-2024 01:16 PM - edited 04-09-2024 01:25 PM
1. Reboot your phone.
2. Not a PM issue. So ignore the contact a CSA post.
3. Check this https://support.apple.com/en-ca/HT204065
4. It’s a setting to be updated or a registry issue. Google it.
5. Make sure your iOS is up to date
6. Lastly, go to the Apple Store for assistance.
And just a tad bit more. You can set all of your other Apple devices (that are using your iCloud account) to also send receive texts (to/from iPhones and androids). Texts to androids with a picture attached will only work, though, from your phone with data turned in.
04-09-2024 12:40 PM
@Matt2002 PM is struggling with new activations , you will need to reach out and hope they can fix for you
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
send a private message To CS_Agents
04-09-2024 12:34 PM
HI @Matt2002
can you get inbound calls?
PM might have some problem with setting up sms capability with new accounts and affected your iMessage activation. Please ask PM agent to refresh your account to fix the problem
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
