01-31-2025
06:36 AM
01-31-2025
07:38 AM
computergeek541
All of a sudden I’m not able to send iMessages. For some of my iPhone contacts, it won’t send the message at all, it says iMessage must be enabled to send this message. iMessage is already enabled. For some other iPhone contacts it will send the message but it goes through as green.
I have already gone into settings and toggled off/on the iMessage switch. And I’ve turned my phone off twice. Any other suggestions?? Thanks!
03-03-2025 02:08 PM
HI @Pike1
can you receive calls and SMS text from friends? If so, this is again a problem with Apple and I don't think PM can help much
Try the remove phone number and add it back after a reboot after waiting for 24 hours
03-03-2025 02:06 PM
Thanks, but it still says waiting for activation under send/receive. I have submitted a “ticket” to the company. I just joined last week.
03-03-2025 01:33 PM
HI @Pike1
the wheel thing is ok, just it takes time for iMessage server
Try remove the phone number from the iMessage Settings first, reboot the phone and wait another 5 mins before you put the phone number back and re-register iMessage. Again, it could take time, but that is more an Apple server issue
03-03-2025 01:29 PM
03-03-2025 12:59 PM
Same problem, but your solution didn’t work for me. In iMessage/send/receive, I couldn’t place a check mark by my number. A wheel beside the number turned endlessly. I tried to remove the number and add it back but it wouldn’t let me remove it. Any suggestions?
02-21-2025 04:42 PM
Yes! Phil answered my post and it worked!
When I went to settings/messages/send and receive/, where it says “you can receive iMessages to and reply from….” My phone number wasn’t ticked off, just my gmail address. Once I ticked off my phone number also and came out it worked!!! I don’t know how it got “unticked” but all good now Hope it works for you!
02-21-2025 04:32 PM
Were you able to find the solution. I am having same issue and public mobile support has not been helpful, not to say its just fragmented and there is no phone no or a person you can speak with directly.
01-31-2025 07:12 AM
@Kellymac Glad it was an easy fix! It happened to me a while back after an ios update.
01-31-2025 06:58 AM
Phil thank you so much!!!! When I went to settings/messages/send and receive/, where it says “you can receive iMessages to and reply from….” My phone number wasn’t ticked off, just my gmail address. Once I ticked off my phone number also and came out it worked!!! I don’t know how it got “unticked” but all good now lol. Thank you!
01-31-2025 06:49 AM
@Kellymac In Settings - Messages - Send and Receive, is everything that should be check marked there checked? Maybe try signing out of Apple and then signing in again. Just checking the obvious, you do have wifi or cellular data enabled?
