iMessage doesn’t work over cellular
Alexkinsellakw
On an iPhone 15 with eSIM, iMessages only sends and receives over WiFi. If I’m on cellular only, nothing sends or receives. I’ve tried toggling iMessages on and off, signing in and out of Apple ID, resetting cellular settings - nothing seems to work. Same for FaceTime.
messages and FaceTime do not appear in Cellular Data as apps either.
CSA_PM
Customer Support Agent
Hi @Alexkinsellakw
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
Alexkinsellakw
Thanks, but the issue is still persisting.
Alexkinsellakw
Thanks! Tried both, but still having the same issues. So far, I've tried:
- Installing a new eSIM
- Reset Network Settings
- Remove and added back phone number in settings
- Signed out and back in with Apple ID
Messages still does not work on cellular and does not appear in Cellular Data Usage as an app.
I've tried two different phones and three different eSIMS.
@Alexkinsellakw
First, Reset Network Settings after a device reboot and check if you can send iMessage on data
If issue persists, remove your phone number from Settings menu, then re-enter it back after a device Reboot to force a iMessage re-registration
