04-20-2026 02:14 AM
I am having trouble activiating my imessage using my phone number. Also, I have two phone lines named "business" and "cellular" with public mobile and I dont know which is connected to my to imessage. Since I cant activate my imessage all the messages I send are sent as SMS. I tried getting support days ago and I didnt get a response so I am posting another.
04-21-2026 01:40 PM
Hello @ Denze,
I sent you a private message. You can view it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
04-21-2026 01:12 PM
No, I am not supposed to have 2 phone lines with Public Mobile. One of them is an eSim and theres an option to delete it but not for the other one.
04-20-2026 06:36 AM - edited 04-20-2026 06:38 AM
@Denze are you supposed to have 2 phone lines or 2 eSIMs with Public Mobile?
If you have only one line with Public Mobile, then check which one should be the correct one first. Turn off one line at a time and set the other one with label Primary. Reboot phone and Reset Network Settings and test
If you really have 2 lines with Public Mobile, then the main line should be set with label Primary and the other one should be set with label Secondary. After that is changed, reboot the phone once
Once you are sorted out with the sim situation, you should disable iMessage for 5 mins , then re-enable it to re-register
