06-13-2018 04:09 PM - edited 01-04-2022 06:10 PM
06-13-2018 05:50 PM - edited 06-13-2018 08:20 PM
Really easy to do. When you log into your account, go to my plan, and change plan. There is an option to schedule the change during your billing period, so you can set it and forget it. Or you can change it there and then. Awesome feature, I have to say!
06-13-2018 05:25 PM - edited 06-13-2018 05:26 PM
06-13-2018 04:13 PM
Did you just sign up? If so DM the mods and they may be able to help you. They may be able to also change your plan and renew it early for you if you’ve been signed up for awhile but require their assistance.
Otherwise, if you’re wanting to change your plan yourself you can do so via self serve. It will allow you to either make changes now or future date them for your renewal date.
06-13-2018 04:12 PM - edited 06-13-2018 04:14 PM
There are no operators to call at PM. You can change your plan your self with your self serve account (make sure you choose future plan change so it will occur at your next renewal) or you can send the moderators a private message. See instructions in the spoiler.
How can you get help with your account, activation, or service?
In your message please include:
Don't know your pin?--provide any 3 of the following:
How long until they reply?:
How can I view my private messages between myself and a Community Moderator
