03-20-2023 03:57 PM
03-20-2023 03:59 PM
03-20-2023 03:59 PM
HI@JohnGodspeed can you still login to My Account?
you can reset the PIN in My Account's profile page
But of course, if you have access to My Account, better to pay there directly
If you cannot login to My Account, then you can try to reset the password, or submit ticket for PM to reset the password
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
