10-26-2024 05:45 PM
my ipnone is locked for infinite time and how to get a phyiscal sim, i have all the evidence master card and adreess proof
10-26-2024 08:38 PM
It doesn’t matter if you use SIM or eSIM if you don’t know your passcode. After 10 wrong attempts. You will be locked out and you need to work with Apple to unlock.
10-26-2024 06:56 PM - edited 10-26-2024 07:02 PM
Alternatively, if it is locked you can just restore the iPhone. You can do that by plugging it into a computer, if you don't have a computer you'll have to borrow someone else's or take it to an Apple store. Your eSIM will then be usable again. Here are the instructions: https://support.apple.com/en-ca/118106
One more alternative, you can simply reset your iPhone without a PC, but this will remove the eSIM if not on iOS 17 or later: https://support.apple.com/en-ca/105090
10-26-2024 06:37 PM
HI @Navreet2753
but unless you are giving up the current iPhone, you still need to work with Apple to unlock the phone first, or you ready to wipe the phone?
10-26-2024 06:34 PM
my iphone passcode was recently changed and now all messed up, and i was using esim and so is it possible to get physical sim?
10-26-2024 06:12 PM
did you perhaps by a 2nd hand cellphone from someone on Craigslist or some such place ? Use this link and check if your cell has been blacklisted. If it is blacklisted...your cell is now a brick, you need a new one.
10-26-2024 05:52 PM
hi @Navreet2753
what is the error message on the iPhone for infinite lock?
so, you try to use a physical sim on another phone?
you can buy a PM physical sim card form Telus or Koodo store or via Amazon:
Telus or Koodo store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
Then message support agent and ask them to help to update your account with the new sim card:
