i cant get in to cancel
10-30-2023 04:46 PM
10-30-2023 05:57 PM - edited 10-30-2023 05:57 PM
You are aware that you are only dealing with other customers on this forum, correct?
We can't do anything to your account.
If you're unable to stop your own subscription in self-serve, you've been given the contact information for the customer support agents to assist with that.
If you are porting your number to another mobile service provider, you don't need to cancel, it'll automatically do so once the port is complete.
10-30-2023 05:00 PM
I asked a few questions in your earlier thread. What is the make and model of the phone? How long have you been having a problem connecting?
https://productioncommunity.publicmobile.ca/t5/Get-Support/not-in-service/td-p/1076930
10-30-2023 04:54 PM
message a CSA to remove your credit card info. Account will deactivate after 90 days in Suspension.
10-30-2023 04:51 PM
To contact a Customer Service Agent, please click on the following link.
Please be sure to keep an eye on the top right corner where you’ll see this icon show up.
