how to get call in code
4268
I cant make calls or text anymore, it says my plan is not activated, it needs a payment (but I'm set up for auto pay🙄)
I cant sign into my account because it wants to send me a code first via email and my email is not set up because I don't use it. It doesn't work to dial *611 because I don't know my four digit code. Can anyone suggest what I could try to make a payment on my account?
4268
Thanks! I bought a voucher from recharge.com and dot into my account!!
hycm53
Sometimes auto pay will fail. So I always put more funds in available funds in my account.
Chat with Simon for this matter, if Simon can’t help, he would let you submit a ticket.
https://www.publicmobile.ca/en/on/get-help
@4268  you should get into My Account and make a manual payment
You can open ticket with PM Agent and have them to help to change to an email address you have access
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
If you need to have the service quicker, get a voucher from Shopper drug mart or online at recharge.com, then use *611 to load the voucher to reactivate first.  You don't need your 4 digits code loading voucher
@4268 @You can try to see if agent can help you with this
Getting help from agent , through automation
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or  get direct help from a agent right here in the community ( my preferred choice )
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
statusquo
I'm sure you can get the code sent to your phone as well.  You can pay with vouchers as well and gas stations and 7/11 sell them and then call 611 on your phone to redeem the voucher.
@4268 @You might have to get a voucher and dial611
