05-28-2023 11:43 AM
Since this site changed I can't load my account and it is impossible to send a ticket into support. My texting service is not working again. How can I contact them? Do they have an external email without needing to log into their system?
05-28-2023 12:22 PM
No. It said my original one was taken - hard to believe cuz I thought that was me from last time but it struggled to get me in and said complete your profile so I made a new nickname. texts work again for me. CS had to reset the network on me. Thanks for everyone's help!
05-28-2023 12:05 PM
Regarding your texting issue -- most likely the fault may be poor reception or your phone settings. I have iMessage enabled and as long as I have good reception all is fine. However when in poor reception areas iMessage also sucks. The same applies to MMS - SMS - that work great in good reception areas and also suck when reception is poor.
05-28-2023 11:54 AM
@bigdog_brown is this the Community id you habe been using? Yes, some customers have problem with setting up the new login on this new system
05-28-2023 11:51 AM
Thank you I have sent a message. Oddly enough I am unable to search for CS agent when initially sending the support email.
05-28-2023 11:46 AM
hi @bigdog_brown chatcot ticket is not functioning. please open ticket with agent by direct message
05-28-2023 11:45 AM
