12-02-2024 03:29 PM - last edited on 12-02-2024 03:37 PM by computergeek541
Hello , please give me a link to contact the manger. I need the instructions
12-02-2024 04:00 PM
Thank you.
12-02-2024 03:56 PM
@TaylorFan22929 wrote:Hello , please give me a link to contact the manger. I need the instructions
while you wait for Customer Support to reply...give us a few details of the problem you're experiencing...maybe we can help before they get back to you.
12-02-2024 03:36 PM - edited 12-02-2024 03:36 PM
did you try login using the PM app?
or tried using Incognito/private/secret mode on the browser to reset password and use the same special mode to login?
if neither works, then ask support agent to help , you can submit ticket by direct message:
12-02-2024 03:34 PM
you have to open ticket the normal way even if you want to talk to any Manager
Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
12-02-2024 03:31 PM
@TaylorFan22929 Here ya go
