12-02-2024
12:55 PM
12-02-2024
01:42 PM
computergeek541
12-02-2024 01:44 PM
@hairbag1 wrote:the esim was free, you musta pre-paid for a plan. You can request a hard sim...OR...get to a Mobile Klinik in your acrea and buy the hard sim there. PM will likely credit your acct for the sim.
I'm acutally wondering if @Daunnie phone has a SIM card slot, or perhaps, the customer can only use eSIM because a physical SIM is already in use in the device.
12-02-2024 12:59 PM
hi @Daunnie
what phone do you have? Sometimes the check is a false negative, you can ask support to confirm
but how about change to Physical sim ? Get one from:
Telus or Koodo or Mobile Klinik store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
Then message support agent and ask them to help to update your account with the new sim card:
12-02-2024 12:58 PM
you can ask PM directly by ticket. You won't be able to open proper Chatbot ticket, so just message them
12-02-2024 12:57 PM
12-02-2024 12:56 PM
