how to change my called ID to my business name
healthyheart
Yummy
You cannot change your caller ID as PM does not send your name to calling phones.
Only your number (if you are not blocking it) will show up at called phone. AND if they have you in their address book then full info might show up.
@healthyheart  public mobile doesn’t have caller  id  just the number shows up . So unless the contacts you call have you added their phone as contact your name / business is the only way for it to show up when you make the call
Dunkman
@healthyheart
Unfortunately, Public mobile does not offer name display for customers. Only the outgoing phone number is shown to others.
Other companies like Rogers does offer name display.
