07-14-2023 09:36 PM
Hi I have a plan of $25 per month with unlimited text and some data, are there any friends can tell me how much I need to pay if I just use it for receiving text out of Canada? Also, do I need enable roaming to receive the text?
Thank you guys,
07-14-2023 10:26 PM
Cost depends on where your friends are located and what plan they are on.
If you are located in Canada, the SMS will be free and you only need Roaming enabled if your friends are sending you a MMS (text with photos attachments).
Your friends can texts and call you for free through WiFi on WhatsApp or TextNow.
07-14-2023 09:48 PM
if you are going to US , just want to receive text, it is FREE. Make sure you connects to T-Mobile network and you can receive text for free
But if you need to send text, reply text, send and receive calls, and/or mobile data, you will need to have appropriate roaming add-ons
07-14-2023 09:43 PM
@Fangfang1 You will need a US roaming add on to use your phone in the US any other country will not work with PM except of course canada
07-14-2023 09:39 PM
PM only works in Canada and probably USA. Incoming SMS is free. It doesn't work in other countries, such as Asia , Europe and Australia
