how do i change my email address for my public mobile account
suzanne55
I gave public mobile an incorrect email address and i can't login to change it to my correct one - help
@suzanne55
You can still login with the incorrect email and use the password and have 2FA code sent by text.
You can have your email address changed with the help from a CS_Agent:
RossN
@suzanne55
hi you need to  to contact a customer service agent for account email reset or change
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
