hacked
FLYING-EAGLEONE
anyone else have odd numbers on their user history?  calls to numbers that are not known to me,  data being used at odd times
1 REPLY 1
@FLYING-EAGLEONE if the numbers end with 4001 or 5002, then no worries, they Re just Voicemail phone number.  PM records all calls routed to Voice mail or when you call to check VM using that 4001 number
This is the full list of the voicemail number that should appear on your usage history
https://productioncommunity.publicmobile.ca/t5/Get-Support/Updated-list-of-Voicemail-Access-Numbers/...
