Data is not working
LeGone23
I can see my account still has remaining data on it but my data just suddenly stopped working.
@LeGone23
Swipe down on your screen on the PM app and it will update your data usage.
If it shows that you still have data then contact a CS_Agent to help you.
So your able to receive incoming calls? You can double check that mobile data is not off by mistake.
Did you do the network resetting?
LeGone23
I've already restarted my phone. I was just using data last night then this morning it just suddenly stopped working
Sansan
First restart your phone.
If that doesn't fix the issue,  turn you data on and off and try again.
Resetting networks should also help.
