03-07-2019 08:22 PM - edited 01-05-2022 03:37 AM
03-08-2019 11:49 AM
@slash407 wrote:i would imagine all carriers use pretty much the same freqency. Pretty sure, dont overthink it and geek out.
@slash407 You imagine? Maybe check first before you post that?
You're somewhat right in that Rogers, Bell, and Telus do all use 850MHz (B5) and 1900MHz (B2) 3G networks, and all 3 operated Band 4 (AWS/1700+2100MHz) 4G LTE as well as some other LTE bands in common. Freedom I think is a different ball game, and I have no idea what networks Videotron/Fizz operate.
03-08-2019 10:53 AM
First of all this thread has already been marked as solved.
Secondly, the first link you provided doesn't indicate compatibility...just blacklist. Much like the checker on this site.
03-08-2019 10:47 AM
Hi Chris3M,
To test your phone’s compatibility with our network, click here. Other good resources for checking phone compatibility include our Community, and willmyphonework.net. Public Mobile uses the following frequency bands:
Please note that this information is indicative only. Your phone's compatibility with our 4G or 4G LTE networks is based on the radio frequencies of your phone. Public Mobile does not guarantee that your phone will work on our mobile network.
Public Mobile Moderator Team
03-07-2019 08:51 PM
@Chris3M, in addition to the link provided by @Anonymous, which provides recommended specs for a phone/repeater, here is the comprehensive list of frequencies deployed on the network:
03-07-2019 08:24 PM
@Chris3M wrote:Does anyone know what frequency Public Mobile uses?
Frequency are identical to Bell Mobility and Telus Mobility.
3g (required for voice calls at Public Mobile): 850 and 1900MHz
LTE: Band 2, 4, 5, 7, and various bands in the 700MHz ranges
03-07-2019 08:23 PM - edited 03-07-2019 08:25 PM
Public mobile = Bell/Telus
https://en.wikipedia.org/wiki/Telus_Mobility#Radio_frequency_summary
Frequency range Band number Protocol Class Status Note(s)
| 700 MHz A/B/C/E | 12/13/17/29 | LTE / LTE Advanced | 4G | Active / Being deployed | Mainly used in rural areas / rural coverage. |
| 1,900 MHz PCS | 2 | UMTS/HSDPA/HSPA+/DC-HSPA+ | 3G/"4G" | Active | Fallback for calls & 3G data. |
| 1,900 MHz PCS | 2 | LTE / LTE Advanced | 4G | Active / Being deployed | Secondary LTE Band being deployed and used for LTE / LTE Advanced coverage. |
| 1,700/2,100 MHz AWS | 4 | LTE / LTE Advanced | 4G | Active | Main LTE Band used across the country. Also being used to provide LTE Advanced coverage. |
| 850 MHz CLR | 5 | UMTS/HSDPA/HSPA+/DC-HSPA+ | 3G/"4G" | Active | Fallback for calls & 3G data. |
| 850 MHz CLR | 5 | LTE | 4G | Active / Being deployed | Used for extra bandwidth within cities and rural coverage. |
| 2,600 MHz IMT-E | 7 | LTE / LTE Advanced | 4G | Active / Being deployed | Found in select markets, but being developed slowly in new markets alongside to provide LTE Advanced coverage. |
03-07-2019 08:23 PM
