12-06-2021 11:31 AM - edited 01-04-2022 05:02 AM
forgot password and security question, account got locked... What can I do
12-06-2021 01:51 PM
12-06-2021 11:44 AM
@Karu it is a one hour temporary lock, you can try again after an hour if you are confident you have the answer to the security question.
If not, open a ticket with PM, click on the Bubble on the lower right or directly at : https://publicmobile.ca/chatbot.
Follow these these to get to ticket open page quicker:
12-06-2021 11:32 AM - edited 12-06-2021 11:33 AM
Contact a CSA.
Hours of operation:
You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in the top right hand corner for a reply from the CSA.
