03-03-2022 01:22 PM - last edited on 03-03-2022 06:50 PM by computergeek541
I want to log into my account to pay my bills through my phone and also keep track of the data, but I don't remember my password and the security also. At the time of buying the representative already made the account for me and choose some random answer for the security question which he doesn't remember.
I want to know how to log in and reset my password.
~Aditya
03-05-2022 04:21 PM
@Bhramastra wrote:no, I never logged into PM account.
@Bhramastra - since you activated in-store, it is likely the store agent did not create a MyAccount/Self Serve for you.
So you can create one yourself, go here to register for a MyAccount/Self Serve : https://selfserve.publicmobile.ca/self-registration/
03-04-2022 06:25 PM
03-04-2022 06:24 PM
03-03-2022 06:44 PM
If your account was created by a PM rep, did you login to your account to activate your Self Serve account?
03-03-2022 02:18 PM
@Bhramastra wrote:I want to log into my account to pay my bills through my phone and also keep track of the data, but I don't remember my password and the security also. At the time of buying the representative already made the account for me and choose some random answer for the security question which he doesn't remember.
Have you Ever been able to log in into your PM self-service account?
Usually customers itself create these accounts and not 'representative'.
03-03-2022 01:39 PM
HI @Bhramastra
Since you do not have the answer to the security question, you can only open ticket with PM Support to have it reset.
Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
03-03-2022 01:26 PM
There are some other options to pay into your account if you're interested but this is how to get access to your account.
Contact a Customer Support Agent
