03-05-2022
04:23 PM
03-05-2022
04:39 PM
computergeek541
03-05-2022 04:33 PM
@NatKirton - are you actually using Recharge.com, found here:
Mobile recharge PublicMobile Canada | Recharge.com
See Get Help Article:
Voucher Payment Options (publicmobile.ca)
Can you describe a bit more of what you are trying to do?
03-05-2022 04:30 PM - edited 03-05-2022 04:31 PM
@NatKirton what exact error?
You were trying to use the credit card on file to pay? Try NOT to pick the option "Amount Due". Use the "Other..." option and enter the plan amount and submit it that way. It should work with this trick
03-05-2022 04:26 PM - edited 03-05-2022 04:29 PM
You may wish to try clearing cache and cookies and opening an incognito tab and logging into self-serve again.
You can also purchase a payment voucher at many locations and apply to self serve or by dialing *611
EDIT: You may also use an online payment site like recharge.com
