02-14-2021 07:27 PM - edited 01-05-2022 05:17 PM
10-07-2021 09:37 AM - edited 10-07-2021 09:38 AM
@Skippy69 did you try the Forgot password link and enter any possible email addresses there? If the correct one is finally entered, you will be able to get to step 2 of the reset password
if you are unable to guess the correct email, please open a ticket with PM using chatbot
Type: forgot log in information
click "Contact Us"
click " Click here to submit a ticket"
you will then directed to another page to open the ticket
After ticket is submitted, make sure to check your Community inbox (top right corner envelope icon) periodically for response from PM
10-07-2021 09:36 AM
10-07-2021 09:28 AM
Hello
10-07-2021 09:27 AM
Hi
02-14-2021 11:01 PM
While waiting on Moderators, I would recommend using the search term "Public Mobile" from a few of the more common e-mail address programs you use.
Look for the activation confirmation e-mail, or any other e-mails SINCE you activated, from Public Mobile.
Your e-mail address linked with your number will be that one.
02-14-2021 07:32 PM
@richakathpa547 : Try using the email used of this community account see if same as your self serve by click on your Avatar icon in top right corner.
02-14-2021 07:28 PM
Hello @richakathpa547 ,
If you cannot search for what email you used to sign up with Public Mobile, only MODS can help you.
To contact the Public Mobile Moderator_Team, there are two ways to reach them:
1 - Faster Method - Click the bubble comment circle on the bottom right hand side of your screen, or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower Method - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
