12-04-2019 08:48 PM - edited 01-05-2022 08:19 AM
Hello .. last week I found a spot in my account that showed me my overall call out minuets that I had used up, but now I can't find that spot. Can someone please refresh my memory where that is located in my account. thanks, Dale .. PLEASE NOTE: message now edited: ooops, ok, I now found the spot, no reply needed now, THANKS, AGAIN, DALE
12-04-2019 08:57 PM
Yup, just found it . .. thanks anyway! *smile*
12-04-2019 08:55 PM
It is usually located on your overview page. If you don't see the counter, it usually means that you ran out of minutes....
See below
