unusual data usage in one day.
08-06-2024
07:04 PM
08-06-2024
07:08 PM
computergeek541
i have checked my data usage and discovered a 5.61G usage in one day. what can I do to verify the finding ?
My Account
08-06-2024 08:51 PM
thank you for your advise.
08-06-2024 07:25 PM
hi @kenfan
yes you can. Just submit ticket
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
08-06-2024 07:20 PM
any channel that I could contact an Public mobile agent for inquiry of this issue ? If anyone may know of
08-06-2024 07:18 PM
yes, the usual data usage was recorded in the usage history.
08-06-2024 07:12 PM
@kenfan , did you find this number in your usage history? Compare this against information from your phone. The two numbers might not align perfectly but should be representative.
