extra charges for out of province data usage?
06-20-2019 11:59 AM - edited 01-05-2022 05:28 AM
My plan includes 250 GB data. Are there extra charges for using data when I am out of my province?
Joining Public
06-20-2019 01:18 PM
Right, NEVER a single charge for pay per use, as pay per use is not what Public does.
If you want to use data in the US, you must purchase the roaming before you use it.
Buy it first, use it when you've paid.
06-20-2019 01:12 PM
@Noor691 wrote:You can use your data outside of your province and will NOT be charged! The only time you are charged for roaming is if you choose to use your data in the USA
Good of you to jump in and participate. Welcome.
If you wish to use Public Mobile in the states then you would need to buy roaming add-ons. There wouldn't be any charges on their own. You just wouldn't be able to text or call out or use data.
06-20-2019 01:08 PM
06-20-2019 12:54 PM
PM plans are prepaid and you can use it across Canada. Once you use up your data then you would need to buy an add-on for more data. Is the amount suppose to be 250 MB ?
06-20-2019 12:11 PM
@wsally wrote:My plan includes 250 GB data. Are there extra charges for using data when I am out of my province?
250 GB!!!??? How did you manage to swing that? 🙂
06-20-2019 12:01 PM
Nope...you can use your data wherever you are in Canada.
