05-28-2024
06:00 AM
05-28-2024
10:34 AM
computergeek541
05-28-2024 11:24 AM
It's not esim compatible due to the model.
You can acquire a public mobile physical SIM card at a corporate Telus or Koodo location. It's a good idea to call ahead first to make sure they have them in stock.
05-28-2024 10:54 AM
@willy6 @Phil_Adelphus @HALIMACS
FYI, when I purchased my first ESIM for an international trip, I learned to test for eSIM compatibility by typing *#06# on the phone dial pad. This causes the phone to display a bunch of information about your phone. If a 32-digit "EID" number is displayed, then the phone should be ESIM compatible. YMMV. Good luck.
05-28-2024 06:56 AM - edited 05-28-2024 06:58 AM
05-28-2024 06:34 AM
dont understand . where is my sim manamger?
05-28-2024 06:26 AM - edited 05-28-2024 06:27 AM
In your sim manager make sure your correct e Sim slot is being used for public mobile services.
The above is presuming you got through to the payment stage and your payment was successfully withdrawn from your credit card.
05-28-2024 06:24 AM
the phone is Iphone 8
thanks for the quick response
05-28-2024 06:20 AM
@willy6 It should be if it is iPhone XR/XS or newer.
05-28-2024 06:14 AM
I set up my iphone yesterday ...my phone is working but in my settings in cellular no esim is indicated. it asked me to add one but not luck says "unable to activate esim . you can try again or try to contact your carrier for assistance.
thanks
